Hi!
Also für Holz hätt ich da was:
Spinewerttabelle :
Spinewerttabelle für 26 inch (660,4000 mm) Abstand der Pfeilauflagen und 2 lbs (907,1847 g) Gewicht
Formel:
0,5200 inch (13,2080 mm) * 50 lbs = Spinewert in lbs
Durchbiegung des Schafts in inch / mm
20 lbs = 9,0718 kg = 33,0200 mm = 1,3000 inch
21 lbs = 9,5254 kg = 31,4476 mm = 1,2381 inch
22 lbs = 9,9790 kg = 30,0182 mm = 1,1818 inch
23 lbs = 10,4326 kg = 28,7130 mm = 1,1304 inch
24 lbs = 10,8862 kg = 27,5167 mm = 1,0833 inch
25 lbs = 11,3398 kg = 26,4160 mm = 1,0400 inch
26 lbs = 11,7934 kg = 25,4000 mm = 1,0000 inch
27 lbs = 12,2470 kg = 24,4593 mm = 0,9630 inch
28 lbs = 12,7006 kg = 23,5857 mm = 0,9286 inch
29 lbs = 13,1542 kg = 22,7724 mm = 0,8966 inch
30 lbs = 13,6078 kg = 22,0133 mm = 0,8667 inch
31 lbs = 14,0614 kg = 21,3032 mm = 0,8387 inch
32 lbs = 14,5150 kg = 20,6375 mm = 0,8125 inch
33 lbs = 14,9685 kg = 20,0121 mm = 0,7879 inch
34 lbs = 15,4221 kg = 19,4235 mm = 0,7647 inch
35 lbs = 15,8757 kg = 18,8686 mm = 0,7429 inch
36 lbs = 16,3293 kg = 18,3444 mm = 0,7222 inch
37 lbs = 16,7829 kg = 17,8486 mm = 0,7027 inch
38 lbs = 17,2365 kg = 17,3789 mm = 0,6842 inch
39 lbs = 17,6901 kg = 16,9333 mm = 0,6667 inch
40 lbs = 18,1437 kg = 16,5100 mm = 0,6500 inch
41 lbs = 18,5973 kg = 16,1073 mm = 0,6341 inch
42 lbs = 19,0509 kg = 15,7238 mm = 0,6190 inch
43 lbs = 19,5045 kg = 15,3581 mm = 0,6047 inch
44 lbs = 19,9581 kg = 15,0091 mm = 0,5909 inch
45 lbs = 20,4117 kg = 14,6756 mm = 0,5778 inch
46 lbs = 20,8652 kg = 14,3565 mm = 0,5652 inch
47 lbs = 21,3188 kg = 14,0511 mm = 0,5532 inch
48 lbs = 21,7724 kg = 13,7583 mm = 0,5417 inch
49 lbs = 22,2260 kg = 13,4776 mm = 0,5306 inch
50 lbs = 22,6796 kg = 13,2080 mm = 0,5200 inch
51 lbs = 23,1332 kg = 12,9490 mm = 0,5098 inch
52 lbs = 23,5868 kg = 12,7000 mm = 0,5000 inch
53 lbs = 24,0404 kg = 12,4604 mm = 0,4906 inch
54 lbs = 24,4940 kg = 12,2296 mm = 0,4815 inch
55 lbs = 24,9476 kg = 12,0073 mm = 0,4727 inch
56 lbs = 25,4012 kg = 11,7929 mm = 0,4643 inch
57 lbs = 25,8548 kg = 11,5860 mm = 0,4561 inch
58 lbs = 26,3084 kg = 11,3862 mm = 0,4483 inch
59 lbs = 26,7619 kg = 11,1932 mm = 0,4407 inch
60 lbs = 27,2155 kg = 11,0067 mm = 0,4333 inch
61 lbs = 27,6691 kg = 10,8262 mm = 0,4262 inch
62 lbs = 28,1227 kg = 10,6516 mm = 0,4194 inch
63 lbs = 28,5763 kg = 10,4825 mm = 0,4127 inch
64 lbs = 29,0299 kg = 10,3188 mm = 0,4063 inch
65 lbs = 29,4835 kg = 10,1600 mm = 0,4000 inch
66 lbs = 29,9371 kg = 10,0061 mm = 0,3939 inch
67 lbs = 30,3907 kg = 9,8567 mm = 0,3881 inch
68 lbs = 30,8443 kg = 9,7118 mm = 0,3824 inch
69 lbs = 31,2979 kg = 9,5710 mm = 0,3768 inch
70 lbs = 31,7515 kg = 9,4343 mm = 0,3714 inch
71 lbs = 32,2051 kg = 9,3014 mm = 0,3662 inch
72 lbs = 32,6586 kg = 9,1722 mm = 0,3611 inch
73 lbs = 33,1122 kg = 9,0466 mm = 0,3562 inch
74 lbs = 33,5658 kg = 8,9243 mm = 0,3514 inch
75 lbs = 34,0194 kg = 8,8053 mm = 0,3467 inch
76 lbs = 34,4730 kg = 8,6895 mm = 0,3421 inch
77 lbs = 34,9266 kg = 8,5766 mm = 0,3377 inch
78 lbs = 35,3802 kg = 8,4667 mm = 0,3333 inch
79 lbs = 35,8338 kg = 8,3595 mm = 0,3291 inch
80 lbs = 36,2874 kg = 8,2550 mm = 0,3250 inch
81 lbs = 36,7410 kg = 8,1531 mm = 0,3210 inch
82 lbs = 37,1946 kg = 8,0537 mm = 0,3171 inch
83 lbs = 37,6482 kg = 7,9566 mm = 0,3133 inch
84 lbs = 38,1018 kg = 7,8619 mm = 0,3095 inch
85 lbs = 38,5553 kg = 7,7694 mm = 0,3059 inch
86 lbs = 39,0089 kg = 7,6791 mm = 0,3023 inch
87 lbs = 39,4625 kg = 7,5908 mm = 0,2989 inch
88 lbs = 39,9161 kg = 7,5045 mm = 0,2955 inch
89 lbs = 40,3697 kg = 7,4202 mm = 0,2921 inch
90 lbs = 40,8233 kg = 7,3378 mm = 0,2889 inch
Bei Carbon fehlt mir jegliche Erfahrung(+somit auch Tabellen)--sorry!
Anleitung Spinetester:
http://www.kaltokri.de/index.php/artike ... pinetester
Gruss-Newie
Umrechnung von Durchbiegung auf Spine
Re: Umrechnung von Durchbiegung auf Spine
Gefahr des Tätigen: Irrtum. Die des Trägen: ihn übernehmen
- Heidjer
- Hat gedankt: 17 Mal
- Hat Dank erhalten: 12 Mal
Die Formel für Holzpfeile ist ganz einfach, es wird die Durchbiegung eines Schaftes gemessen der im Abstand von 26“ (26 Zoll = 66,04 cm) auf dünnen Lagern aufliegt. In der Mitte wird er mit 2 # (2 Pond, 2 lb bzw. 907 Gramm) belastet. Mit der gemessenen Durchbiegung kann dann der Spine errechnet werden. Nach der Formel: Abstand / Durchbiegung = Spine, 26“ / 0,5“ = 52 # oder in Deutsch 66,04 cm / 1,27 cm = 52 #
Das stimmt aber nur für Holzpfeile, bei Carbonschäften wird der Spine in 28" Abstand und mit 1,94 # gemessen, darum wird bei Carbon auch der Spine nicht in Pound angegeben sondern die Durchbiegung in Tausendstel Zoll, zB 500 bedeudet eine Durchbiegung von 0,5 Zoll.
- klaus1962
- Hat Dank erhalten: 5 Mal
... nur zur Info : Die Links sind nicht ganz tot, sie haben sich nur leicht geändert.elBohu hat geschrieben: #Leider sind die Links tot...
... der hier funktioniert.
da PDF : http://marshal.ansteorra.org/archery/fi ... 01/aob.pdf
bzw. die Seite gesamt: http://marshal.ansteorra.org/archery/
