The Hedge is here
- Haitha
- Hat gedankt: 183 Mal
- Hat Dank erhalten: 61 Mal
Re: The Hedge is here
Lucky you. Life is good.
Ever since I‘ve accessed to PA, I dreamed of attending the TClassic and meeting everyone. I also own CDs from Will Harrisson and a book from Jimmy B.
Thanks for the information.
Any particular reason why you use edge grain for this?
- HedgeHunter
- Jr. Member
Known them both. The former is a good fellow, the other well he OK I guess.
Thomas usually if you take time tillering you can get some to stay. It depends on the quality of wood and how much early growth it has in stave. More late growth will give you better reflex. Even if holds to even limbs thats great result
HH~
HH~
Making Amerika Primitive Again - MAPA
- HedgeHunter
- Jr. Member
Have the bow out of form now and almost ready to tiller. Floor tiller is complete. Will put tip overlays on it to start the formal tiller process. Looking OK for now. Should make a nice shooter with a shelf so arrow can sit on it while hanging up.
Hedge~
Hedge~
- HedgeHunter
- Jr. Member
Got tips on bow and have some heat alignment to do as the string is favoring the off shelf side. Should not be very difficult to align the limbs with some heat on the form. then on with finishing tiller. Floor tiller is complete as well. it is 65 inches from sting grooves and 67" overall length.
HH~
HH~
- Hat gedankt: 76 Mal
- Hat Dank erhalten: 243 Mal
Hi, are both limbs the same length or is the upper one shorter?
Greetings Thomas
Greetings Thomas
- HedgeHunter
- Jr. Member
Same length Thomas.
First brace after floor tiller. Still heavy. In no hurry as I have working in forest now.
HH~
HH~
- HedgeHunter
- Jr. Member
- HedgeHunter
- Jr. Member
This bow is getting last coat of finish today. It has a very interesting date on it.
45Lbs@27"
9-11-2021
It is gong to US Army Combat Veteran from the War on Terror. So, the date will have some meaning for him. Twisted up a nice 8125 BCY string for it and it shoots extremely well 40-45 spine arrows and 145grn points. Bows hols about 2.75" of reflex after getting it shot in.
Hedge~
45Lbs@27"
9-11-2021
Hedge~
Hi, the finish looks very good, which oil do you use?
Greetings Thomas
Greetings Thomas
- HedgeHunter
- Jr. Member
I use a sealer then Tru Oil and usually go with poly over top if it will be in the woods a lot. I have to get a finished profile of this one strung up. Its a killer, shoots flat and fast.
HH~
HH~
- HedgeHunter
- Jr. Member
Here it is complete. Ready for the woods.
HH~
HH~
Aye,man,quite good looking Bow you made
Won't go to more draweight? 45# is ,maybe, not enough for you,i assume. I'm going to my 6ties,and so is my draweight,about 60#+.
As you are ,maybe,much younger than me, I'd like to see some Bows of yours exceeding the "Common Comfort Zone".
Greets,
Greets,
- HedgeHunter
- Jr. Member
Im about sixty. The man who wanted a bow had picked the weight he wanted not myself. Heavy bows are easier to build to me. Very easy to build 60-70lb Osage bows, not nearly as hard as building a very good performing 25lb Osage Bow.
I have no reason to shoot any bow over 55lbs. The are no Mammoths or Dragons left.
Hedge~
Hedge~
Right,absolutely, for me it's Dogwood (Cornus Sanguinea+ Cornus Mas) ,never did anything with Osage.Anyway I learned most by building Bows for my sons and neighborhood-children.HedgeHunter hat geschrieben: ↑16.09.2021, 14:20 ...not nearly as hard as building a very good performing 25lb Osage Bow.
Reliable and performing is ...uuuh... not the easy way..
Nja,some reason is funHedgeHunter hat geschrieben: ↑16.09.2021, 14:20 I have no reason to shoot any bow over 55lbs. The are no Mammoths or Dragons left.![]()
And,around the Lake is a great variety of elaborate bows,all existing at the same time. From very flat to ELB-style,thousands of years old.. no Olympic or Sports-Bows..
To the mammoths and dragons... : hmmm,nay,not even here in southern Germany
Greets,
Made my day.HedgeHunter hat geschrieben: ↑16.09.2021, 14:20 I have no reason to shoot any bow over 55lbs. The are no Mammoths or Dragons left.![]()
For me 40# is enough.
Thomas
